September 4Sep 4 Good Day ,I have a 350cc Merlin Cagiva which has pretty much overnight developed an engine issue. It will now not fully rev. The engine sounds muffled when revved, like if the exhaust silencer was blocked ( which it is not).I have checked the carb, cleaned the jets, tried different jets and even tried a new carb. This did not solve the issue.I checked the coil and tried a new coil. This did not solve the problem.I checked the stator and tried various advance and retard positions. This did not solve the issue. For my sanity, can anyone explain to me how the CDI works? The engine when was running fine, the stator was pretty much on TDC. Does the CDI then deal with the timing of the spark when the engine revs are increased. Not having an useful specs for the engine, I assume that TDC is correct.Whilst taking the flywheel on and off, I did detect some movement in the main shaft. I doubt if the main bearings have ever been changed! If the bearings are faulty and subsequently the main seals may be faulty, could this possible be the source of the problem ( taking in air or pushing out fuel ). The engine is not smoking excessively, but maybe that is due to bearing/seal failure only being on the flywheel side.I have approached Rex's Speedshop for advice, but before I part with a small fortune on a new ignition system, I thought I would ask you knowledgeable guys for advice.Kind RegardsBruce
September 4Sep 4 Ignition timing is usually slightly advance to TDC typically 10 to 20 degrees before and the black box is what alters the spark advance more if the engine even has that feature, it might not. I found a parts manual online for that bike no problem no luck with a service manual. Faulty bottom end seals destroy the engines intake vacuum more then anything else (symptoms would be poor compression test, hard starting and not a crisp pop pop pop sound on the engine). Your CDI trigger coil should show some resistance, more resistance than the primary ignition coils typically have. The clearance distance between the stator coils and the flywheel magnets should be as small as possible for the best spark intensity. One of those coils is likely for ignition and the other is for lights or horn.Only way I know of to test the black box 100% is to have a second working bike and swap parts to troubleshoot. Edited September 4Sep 4 by lemur added stuff
September 16Sep 16 Author Hi guys. Would any of you happen to have a Merlin, who could maybe tell me what the complete part number is on the Kokusan CDI.I do know that Merlin used two systems, Kokusan and Dansi.As you can see from my photo, I only have CU 21. There are more digits or numbers after that.ThksBruce
September 17Sep 17 Looks like you have damage on the lighting coil?, potentially also damage to the ignition or pulse coil or even the damaged lighting coil is affecting the other coils.Have you got the resistance values for the various coils?
September 17Sep 17 Author Hi There, I did notice that , but there is no problem with the strength of the spark, it just seems to be firing at the incorrect time.This points me ( no pun intended ) towards the CDI or the Hall sensor.I think I have a long journey ahead.ChrsBruce
September 18Sep 18 I assume it is running fine at Idle?What happens when you rev it out in Neutral?What happens when you try and rev out under load/in gear?
September 18Sep 18 Author Hi There,I have done a bit more checking with my trusty multimeter.I have tested the resistance on the hall sensor/pick up coil. It measured 23,5 ohms. But what I do not understand is that I get this reading with one probe of my multimeter on the wire from the sensor and the other probe going to earth. Is this correct? In my simple brain the pulse from the sensor/coil will not go to the CDI, but straight to earth. I have also discovered that the damage to the lighting coil was done by my flywheel puller.ThksBruce
