October 24Oct 24 How do I stop the fork damper rod spinning as I try to tighten the bottom bolt after an oil change? Tried to jam some copper pipe down the inside of the fork leg but no joy. I can'tsee what nut or fitting is inside or I would make something. Thanks.Ps. Ive had the forks well compressed with a ratchet strap, I need something inside the fork.
October 25Oct 25 Push the fork into the ground to compress the spring a bit and use an impact driver.
October 26Oct 26 On 10/24/2026 at 3:59 PM, fastfred said:How do I stop the fork damper rod spinning as I try to tighten the bottom bolt after an oil change? Tried to jam some copper pipe down the inside of the fork leg but no joy. I can'tsee what nut or fitting is inside or I would make something. Thanks.Ps. Ive had the forks well compressed with a ratchet strap, I need something inside the fork.As @kurtas says , a battery powered impact gun or air type if you have a large air compressor in the garage. Spend money on tools for the job or struggle , its your choice .
