Ty175 Help
hi ive got a dilemer with my clutch what it is is that i start the bike up and then pull te clutch in and put it into gear and it pulls away without even letting the clutch out
You just need to free up the clutch, just put into a high gear pull the clutch lever in rock it back and forward and the clutch should free. Then start up away you go! in a gear of your choice. Do I need to answer the 3 posts :D
