May 19, 200620 yr Just looking for a few pointers in setting up the rear shock unit on the 2005 raga 300pro. Whats adjustable etc etc and how. thanks S.M.
May 19, 200620 yr Here's a link to the owner's manual, straight from the ohlins website. http://www.ohlins.com/pdf/07252-01.pdf
May 19, 200620 yr For the 2006 Ohlins Kev at GasGas UK sez "I set all our bikes here like this, measure the length of the shock spring when the bike is on a stand & it should be 120mm (gold ohlins), then turn the black damper nut all the way in (up the shock) then back it off 20 clicks. With the front forks we just set the comp & rebound to there softest settings & leave them there...." I was asking about an 06 250 (with a gold ohlins) I am not sure exactly what the raga uses.
