Squeeky Font Brake
Hey guys, My front brake on my montesa is squeeky all the time, all it does is the louad squuuuueeekk what should i do to fix it?
Cheers chris
ask hugh, he will tell you to clean the rust of the bolts that go through the shoes, as they slide on the bolts and cause the squeek
Your pads are vibrating on the piston puck.
Either the steel part of the pads are warped or there is a bunch of crap stuck between pad and puck.
Take them apart and clean them or replace the pads.
If all else fails go to your local and supply store and pick up some anti vibration lube that they sell for the same problem with car brakes.
Cheers
BillyT :)
