Master Cylinder
i had a fall on my sherco and snaped the braket on my front brake cylinder do any of you know how i can fix it or will i need to buy a new one and where would be the cheapest??
any help would be appreciated
haven trialsport have master cylinders and im sure most other places do as well
I dont think it could be fixed??
Next time put it on more loosely so is can slide under pressure
it was on loose it got twisted in a log , do you think ally welding would do it??
we gasgas folk wouldn't know about sherco parts...
I doubt that one would be effectively repairable by welding.
Might be worth a try, but I would be concerned of deforming the bore.
I had one welded, the bracket ear, somewhat away from the bore. It worked ok for a while, but only reason I did it was to buy time to find another one. Was a 96 and hard to get parts. Ended up with a Pro takeoff from Mizell as the permanent fix.
If you need to, I'd have it welded, but only as a short term fix. Belly up to the bar, spend the $US100+ and figure it's cheaper then MX rebuilding engines.
k
