4t Cam
Got my easy start kit and was wondering
in the photos of the new cam it mentions two .5mm washers are they supposed to
be in the kit or do you use the origionals ?
got the rest done (started second kick)
But am summoning up the courage to take the motor apart this weekend
Dixie
I didn't receive any shims with my kit.
I just used several from the original as required to get the end float
correct.
RE500
Boy's
Riding the 06 4t from the factory on sunday. I will let you know how it goes. Ishy hope you have not crossed over to the dark side like Big John :)<_<
Just for future reference.
Can you tell at glance (or close inspection) if a 3.2 has had a hot start mod fitted? <_<
If so, how??
Best of balance.
Neo
Edited by Neo
If so, how??
Best of balance.
Neo
With the factory hot start kit, the operating lever is attached to the clutch master cylinder cover.
So, just glance at the bars :)
Cheers
RE500
neo
just see if it starts ;
no seriously the kickstart is longer as well,but as RE says look at the master cylinder on the clutch side
only fitted part of my kit and it starts really well ,maybe because i can use the choke again .
