Tipped over yesterday and now shifter will rotate 360 degrees.
Did my searching here, and it seems that this is not unheard of, and I may be able to fix it without splitting the cases.
I've watched all the repair videos, which make reference to the issue, but do not actually show the procedure to repair/replace the "top hat" on the right side of the shift drum, under the clutch.
I do know that there is a circlip which holds the piece in place.
If anyone is familar with the part, could you walk me through inspection/ repair from the right side: let's say I have the clutch cover and clutch off.
Looking at the parts list I see "SHIFT SHAFT CENTER LOCATOR AND SPRING" MT280238037CT. Is that all I would need if I don't have to split the cases?
TY in advance
Edited by uhoh7, 06 June 2010 - 07:35 PM.
