Trials Central: Is This Normal? - Trials Central
Page 1 of 1
  • You cannot start a new topic
  • You cannot reply to this topic
Is This Normal? Rate Topic: -----
#1 User is offline   colin1212
  • New Member
  • Pip
  • Group: Members
  • Bike:Gas Gas TXT PRO 280
Posted 14 July 2010 - 02:38 PM
Just got my bike fixed today by a local trials mechanic, he worked on it for about a week. he cleaned out the engine and replaced all the oils. I started it up and it sounded so much better. I got off the bike and put the stand down, then i noticed the bike is about to fall. I cant put the stand down because when the engines on it falls over?. Is the revs to high?. There is a slight rattle from the engine aswell.
#2 User is offline   JSE
  • Advanced Member
  • Group: Site Supporter
  • Bike:Gas-Gas Pro, TY350s
  • Club:NEOTT-Life member, Texhoma Trials Club, AMA-Life Member
Posted 14 July 2010 - 03:08 PM
Slight engine rattle in neutral is normal if it mostly goes away when clutch lever pulled in (my guess is the "fingers" slightly loose on the pillars).
Falling over is not normal and may mean the kickstand has been bent. Ask your mechanic to look at it.
Jon
#3 User is offline   colin1212
  • New Member
  • Pip
  • Group: Members
Posted 14 July 2010 - 03:28 PM
Jon
Thanks Jon, I just noticed the bent kickstand. Any easy way to fix the kickstand?
#4 User is offline   mark1984
  • Advanced Member
  • PipPipPip
  • Group: Members
  • Bike:montesa 4rt
Posted 14 July 2010 - 03:43 PM
take it off and take a big hammer to it
#5 User is offline   JSE
  • Advanced Member
Posted 14 July 2010 - 05:02 PM
You'll need to take it off. Two V-blocks and a press is the best way but you can use two 2X4's as the V-blocks
and a third short 2X4 to pound the bend straight with a heavy hammer. The 2X4 on the bend will not cause a flat
spot like a hammer blow would and it spreads the force out a little on the spot to avoid kinks.
Starting the bike while the kickstand is down is a very common cause of bent kickstands. They are only designed
to hold the bike up and any more weight on the light components will bend them quickly.
Jon
Share this topic:
Page 1 of 1
1 User(s) are reading this topic
