C15 Gearbox Problem ?
broony
Riding round the garden today on the C15 and had to reverse
the bike in gear with the clutch pulled in and it wouldn't go
backwards unless it was in neutral.The clutch is fine and clears
all the gears,is this normal????.I have never noticed this before
(recently changed gearbox camplate with upgraded part,gear
change is fine),could it be something to do with the kickstart/pawl
as it's action now seems further forward than it used to be.
cheers the noo Brian
Ross,no problem in neutral.It only happens when
in gear and trying to manoeuvre the bike backwards
with the clutch in.The only thing I thought it might be
is the kick start as its on the end of the transmission.
I'll strip the outer casing off tomorrow and have a look.
Are you going to Drumcarrow on Sunday?
Edited by broony
I had a similar problem that turned out to be that the rear wheel was out of line and the chain was trying to ride over the rear sprocket, stopping the wheel. I know you said it only happens in gear but worth a look ( it only happened when going backwards)
Edited by davetom
Good suggestion from davetom, that also happened to me, chain was on top of sprocket making it really tight.
Now run with the snail cams 1 out from side to side.
Probably going to Bedlington trial on Sunday Brian.
Up the shed tonight,checked the gearbox and shift all seems ok.
Can anyone with a C15(dizzy motor) see if they can have the bike
in gear(1st will do) work the clutch and see if the bike can be
pushed backwards in gear with the clutch in(freewheel).Mines locks up
trying to do this(never noticed this before and not good if stuck
on a section).They may all do this ??????
Hi Davetom with the bike on the paddock stand and wheel in the air
it locks up,I can turn the wheel forwards but not backwards,think
it has something to do with the kickstart pawl as its on the end of
1st gear.
Problem solved ,found out what was causing the problem.
The kickstart return spring retaining screw holds a stop
plate on the inner cover never noticed it had fell out.
the stop plate was lying at the back of the gearbox.The
screw was never tight and I thought it was stripped in
the cover.Lesson learned .
Edited by broony
