andy63
    2
  1. Hi Jon, Thanks for the advise. I have tried adjusting the lever but this has not sorted the problem. I am now going to remove clutch pack and do some measuring to ensure the pack is the right thickness. I did not detect a thicker friction plate when i put the pack in but i will check and keep you updated, Thanks again, Andy63
  2. I have just purchased this bike. When i got it the clutch was dragging making it difficult to select neutral. I replaced the clutch which sorted the dragging out but now i have slippage in the higher gears, I am using ATF in the engine. The clutch operated fine in 1st to 3rd but slips in 4th to 6th when riding hard. I do not appear to be loosing clutch fluid so have ruled out the actual hydralic system. Does any one have any suggestions as to what the problemmight be. I have thought the clutch operates right at the top of the lever action almost as if the lever is not allowing the clutch to fully enguage when i have let it out. Not sure if i should adjust the lever settings?? Clutch has done less than 5 miles since replacement. Hope you can help me with this one. Many thanks Andy63
