Hi we had the same problem i here in DK. if you loosen the bolt for the swingarm it will probably disapear. !!! the cure is to take of the swing arm and with a file, thake a few tenth of a mm away, you will be able to see where the swingarm rubs and is too wide round the end where the bearing sits.
It helped here.
