ryandude
    4
  1. he been a bit silly and removed them for inspection and needed new bearings so pushed them out, now i cant remeber which way they fit back. i know the smaller hole of the 2 is the top but do the dog bones taper in or out? its a 1995 jt350 cheers front of bike or front of bike [ ] [ ] / \ \ / / \ \ / / \ \ / [ ] [ ]
  2. hi had another look at the bike. the kick start has about 20degrees of freeish rotation, and then is stiff, do you think the kick start shaft might be bent?
  3. Hi cheers the washer in there looked a lil home made any body know the correct thickness so I can see if its the correct 1? cheers
  4. he just got a 1995 jt 350 1st trials bike, starts and runs well, but kick start was flopping all over changed the kick start return spring but now its stiff and does not return just sits where its left when kicked. turned the bike off and moved the kicks start back but is very stiff to move by hand. any ideas what it is? oil levels good coolant levels good too. any simple solutions/ ideas to help? cheers Ryan
