Hi all,
Been re-building my GGTXT200 yr 2000 up after doing the crank bearings. I took the casing and selector drum to my local trials shop after I got stuck setting it up. The guy there kindly set it up for me. I put the two gear clusters back in, and with the drum in the neutral position, put the selctor forks in. I tried running through the gears but somethings wrong. with the selector drum in neutral, both clusters rotate..I can go one gear down..but not up the clusters seize. Can someone take a look at the photo below..Is my drum/sprung snubbers set up correctly..it's the only thing I can think of which can cause the problem.
Cheers,
Col.
