27 -
Ah cheers guys, unfortunate for me i spent on 2 camping pitches for a group, grrrrr but hey i gotta travel from top of scotland down there 6hrs drive so im sure we could just rough it somwhere, i hope,
Anybody up for a open day with the Lochinver trials club Sunday 1st of june Glen Canisp 10am start please get in touch for more info free for all
Hi all just wondering if anybody been before can give us the heads up on the best sections to watch also does anybody no what a pitch on the campsite consists of ie can i get my car and tent on it, power supply thanks footpegleg
Is there a different litre capacity or are they all the same size, the other one i seen seemed to be skinnier def was not as bulky as mine i wondered if it was a smaller size maybe my own one is fryer tucked it bulges out over the frame there is also one point on the underside of the tank that seems really weak plastic i can push it right in with a finger and that is without the hot water in grrrrrr spent 2 weeks servicing my bike few new bits added all nice n clean and last fing to go on wont fit prob gonna need new tank, guess i willnae git oot afore the ssdt
Hi all sorry been away so long bike been goin so good now i have no probs However my bike has been in bits now for over a month and i am getting it cleaned up and back together slowly My problem now is that the petrol tank will not fit back on my bike to big , far to big I have done the whole boiling water in then squeeze back to shape that worked the last time but this time way to big hmmmmmmm. It seems that this time will not go back to shape Anyway I have had enough of this now, even after i got it in last time it still did not line up proper with the mudguard so that annoyed me 2 The other day I was looking at the 2007 290 and its tank seemed to fit neater than mine looked like a smaller tank but it fitted nice and snug into the frame and under the mudguard Does anybody no where i can get a new one or secondhand Cheers for reading Footpegleg
I have a 2008 sherco 250 and when i got my stand same thing, but simple zip tye was the answer for me and no more rubbing!!! however when i have the rear tyre pressure down to about 5psi some big drops and jumps it still touches barely so that would be your best bet I fink, Are u in the buie??
thanks guys try this out the moro
So any tips on getting the air out
I snapped one of my bolts on my ajp master cyl front I removed resevoir, brake cable, and caliper (just got ma forks serviced) Replaced brake pads.... So I first open nipple, then lever the pads open (think at this point I pushed the pots all the way back) Remove screw and wire clip from caliper then take out old pads New ones put into place screw and clip back in Remove rubber from resevoir open banjo bolt and drain the old fluid out working way down Unscrew the banjo from caliper and remove all old fluid from there All screws tightend back up fill the resevoir pump like mad for wee bit then open close the nipple AHHH NO PRESSURE ATOLL Pads and pots not moving one bit and a spongy lever grrrrrr What I do wrong??
Does anybody no where I can get a decent tyre pump that I can carry with me when im riding my bike I use a air compressor (50litre) in garage but cant carry that with me Its a pump im looking for with co2????? i dont really no of any good ones Has anyone got one they would reccomend to me or no where I can buy one Cheers
opps meant this one to see how tight it is
In this picture the brake pipe coming out from the bottom of the resevoir prevents me from adjusting the brake lever to suit my need also you can see the throttle housing sitting atop of the resevoir Would a rear exit pipe on the master cylinder be a better option or is this the way it is meant to be??? This picture shows just how tight to the bars the pipe is, Is this all normal??? Cheers for looking
After fitting new bars on bike my front brake was bit loose, so tighten it up and SNAP, the bolt snaped grrrrrrrrrrrrrrr Im looking now for a new master cylinder and im not sure about the brake cable It is very tight to the handlebar when fitted and i noticed that the ones for sale, some of them offer rear exit pipes Would this be a better option for me as my throttle housing sits right on top of the cylinder cover as the pipe from the brake is flush with the handlebar and thus gives it no play Anyone got any ideas as were to get one that is right for my sherco 2008 250, now with jitsie high rise bars Cheers again footpegleg gm
OK scrap the risers got new bars the bigger ones much better improved wheelie time too wohoo
Hey thanks again copemech, pure wealth of knowledge u have
