Hello again, The TY250 59N model you have originally had a restrictive airbox lid & would of had the following jetting as standard :
Tekei Y26P/1 carb
Main Jet 110 , Needle Jet 2610,Jet Needle& clip position 5C95-3, Cutaway Slide 2.5,
Pilot jet 48, Air jet 2.5mm ,Starter Jet 0,7, Airscrew 1 1/2 turns, Float Height 22mm , Spark plug NGK B7ES. Ign. Timing 2.8mm BTDC. Compression 7.6:1
TheTY250R Model number 38V/44J/44H differs in having a free flowing airbox lid & lighter flywheel. Carb specs for this model are: Tekei Y26/P1
Main Jet 140, Needle Jet S-00 , Jet Needle & clip position 5C95-3, Cutaway Slide 2.5,
Pilot Jet 40, Air jet 2.5mm , Starter jet 0,7, Airscrew 2 1/4 turns,Float Height 22mm,
Spark Plug Champion N-5G , Ign. Timing 2.8mm BTDC. Compression 7.8:1
The TY250R(last model ) 2AF 38V-010101 Different Piston to earlier models.
Carb specs for this model Tekei Y26/P1
Main Jet 135, Needle Jet S-10,Jet Needle & clip position 5C99-3, Cutaway Slide 2.5,
Pilot Jet 38, Air Jet 2.5mm , Starter jet 0,7 , Airscrew 1 1/2, Float Height 22mm ,
Spark Plug NGK BR6ES , Ign, Timing 2.8 BTDC , Compression 7.0:1
A few points to take into consideration: It's very easy to chase a jetting problem when  the carb is worn, especially the slide, as this could be letting air past it.I put some new jets in & the bike was a lot easier to start.Also it's possible to have the carb settings correct , but be spoofed by a too rich pre-mixture (wrong oil ratio )or old fuel which will both give the symptom of weak carb settings.
Hope this helps your situation, Regards Plodder.
