Hi there, I recently purchased a 2002 gas gas txt pro 200 which I was told needed a new clutch. Once the bike was home I stripped the clutch down cleaned up the plates and re-assembled. however when the clutch was out I did notice some marks on the gearbox casing where it looks like the clutch has been catching. I presumed this was a maybe a problem from the past as it fitted back together fine, but after a couple of rides out it has started to get very noisy. so i decided to drain the gearbox oil and found some large pieces of metal stuck the the sump plug. could there be a washer missing that sits the clutch assembly further forward that has been removed at some point?? i did watch the clutch removal tutorial on youtube and it didn't seem as there is supposed to be anything. I have attached an image of the marks on the case if anyone has seen this before could you please tell me what is going wrong ??
Thanks
Mike
