timmowatts
    8
  1. Looking at it, I believe the reservoir has been changed. It has a straight spigot instead of an angled one, that is why it doesn't sit correctly. The bottom of the tank is pushing down on it and the straight spigot is trapping/kinking the pipe
  2. I thought it would be M10 but knew there was 2 thread pitch, just wanted to make sure I got the right one
  3. Bought the bike about 6 weeks ago, the seller said he had moved the rear brake reservoir due to exhaust melting the pipe or something like that. Attached photo shows where he has fitted it, can someone show me where it is supposed it be fitted. Also I need to change the rear master cylinder, the brake light switch/banjo is no longer needed and a bit suspect so want to replace it with a banjo bolt, what size/ thread pitch is it? Cheers Tim
  4. Thanks, I'll try the water test to make sure. Yes, know the brakes will be DOT It's just the clutch I wasn't sure about 👍
  5. As title says, frame number suggests it's build is march 04. The master cylinder tops have been changed for aftermarket ones so can't go by the colour of the top. I had the Idea to take the top off and dab a cotton bud into fluid and rub it onto a painted surface (not on the bike 😉) and it took the paint off, so assuming I have DOT4 and not mineral oil unless that strips paint as well 🤔 Want to top up master cylinder and fit a repair kit. Cheers Tim
  6. Thought I'd been a member on here before, but obviously not 😂 Got a 2004 Gas Gas TXT 200 Pro
