davide123
    4
  1. Thanks a lot for your suggestions!
  2. Thanks a lot for your suggestions, i'll try to check minimum rpm's and clearance valves.
  3. Hello everyone, I have a problem with a 2005 Cota 4RT. After 10/15 minutes of riding, the bike shuts down, it seems to be a lack of fuel supply. As soon as it happens, I remove the spark plug and find it dry. After this, the bike starts up again immediately but then shuts down again after a few kilometers. I have replaced the fuel pump and filter, but with no results. When the engine is about to shut down, if I pull the clutch, it does not shut down, so in neutral position the engine runs well without issues; as soon as I shift into gear and increase the revs, it starts to misfire until it shuts down. Has anyone ever had a similar problem? Thank you for the help!
  4. Hi everyone, I'm a new member, writing from Italy. I own a Beta Rev and a Cota 4RT.
