Seabag
    6
  1. I need new footpegs for a Vertigo Nitro 250 2022. Any recommendations?
  2. Mine can't slide all the way. It's stopping about 1 cm short and seems to be blocked by the Allen bolt. — I guess thats normal?
  3. Seabag
    Fork Oil Level
    I appreciate all the responses, they really helped me.
  4. Is this kickstart shaft the same as V-0231 – KICKSTART SHAFT? I'm having trouble getting the parts to fit together properly. My bike is a 2019 Vertigo Vertical Combat 250cc, and I'm using the original Vertigo kickstart lever. However, I can't seem to get it to fit correctly onto the shaft. I was expecting there to be a groove or slot in the shaft for the cross bolt on the lever to lock into, but it doesn't seem to be there.
  5. Seabag
    Fork Oil Level
    I'm new here and have just bought a used 2019 Vertigo Combat Vertical 250cc. I'm about to change the oil in both front forks, but I'm a bit unsure about the correct oil level. In the service manual for the bike, it says the oil level should be 130 mm in both forks. However, in the service manual for the forks — which are Tech Suspension — it states that the level should be 130 mm in the left fork and 75 mm in the right. Which one should I trust?
  6. Seabag
    Service manual?
    Is there a Service Manual for the Vertigo 2019 Vertical combat 250cc? I can only find the Spare Parts pdf and the Owners Manual pdf.
