twismo
    8
  1. no,you dont realy need a light, i would hardly use it, just looks a bit strange when there is no bulb in the socket. but thanks for the advice
  2. i have just been riding about with the light on for a few minutes,the light gets warm but not hot enough to melt the plastic, i dont think the bulb is being given enough power to light the bulb to its full brightness.any help appreciated.
  3. i have had my gasgas 09 125 for a few weeks now,and the little led light at the front has broken,so i went to get a new bulb for it. I came back with a 12v 20watt halogen bulb i fitted it, its quite bright and it gives out a little bit of heat like the hologen ones do but i was wondering if fitting this bulb will dammage the electronics on the bike at all.the bulb that i took out of it was a 20 led 12v 3watt bulb.
  4. thank you so much i have just tried it and it starts in two kicks.no more sunday mornings turning the engine over. thanks again
  5. so could this be the problem then? me not pulling the choke up fully.and that would explain why it starts easy once warm and not when its cold?
  6. i was having a look at the choke mecahnism today, and whenever you pull the choke lever up nothing realy seems to hapen to the engine.when i pull the choke up the the brass rod beneath it doesnt move but if you pull it a little further the brass rod starts to move and i was wondering if you have to lift the choke lever untill it points to vertical because we have only been lifting it to about 10 degress?
  7. Dellorto Any help appreciated
  8. Hi all 1st post here. New to trials & have jumped in with a new 09 125 Gasser which is fab-only problem is that if it doesn't start 1st or 2nd kick when cold you can be turning it over for 10mins or so before it finally goes.Have checked plug which is always dry. Once going it starts 1st kick all day long. Any ideas?
