dpetrick
    2
  1. dpetrick
    09 Problems
    I wouldn't be concerned about the broken teeth on the starter gear. True it does happen, but also true they have improved this part (twice now if you count the 2010 model). I have broke a couple of these gears one each on two differnt bikes. First broken gear was while starting the bike while rested on the skid plate on a rock. Snapped the tooth right away. Second was on my 300, as mentioned earlier, they are a bear to start. If you looking at a 250, I would be willing to bet you will never have a starting gear problem. Bottom line is if the gear breaks, it's an easy fix to swap the new gear out and usually doesn't cause any other problems in the motor.
  2. What's going on with the new Gas Gas 4 stroke? I haven't heard anything about this new bike since it's debut several months ago. Are they available anywhere?
