45 -
I have just bought a 2013 300 raga to replace my 2012 one and when I went to set the rear shock up I found that it was upside down compaired to the 2012 raga,ie the compression is at the bottom not the top and I am finding it hard to adjust it because of the linkage,is there an easy way or do I have to take the shock off to adjust the compression thanks for any info kind regards tommy
the problem turned out to be a burnt out coil on the stator,,,thanks for all the help,,,,cheers
can you run through the procedure for checking for a spark and the kill switch,,,do you just disconect the switch,,thanks tom
hi there was wondering if some one could point me in the right direction,,,,i was riding my bike and then all of a sudden it just died,when i tryed to start the bike again it ran for a couple of seconds and then died again,,since then will not start,there was no indecation of anything wrong before this happened,i have checked fuel and air ,,,carb,,,and have put a new plug in,,,and it still will not start,,,,has any one got any ideas or has anybody had this happen to them ,,,thanks tom
will do ,,,thanks for all the info.....thanks
my 2007 raga 300 runs fine when the throtle is open,, but when on tick over seens as though its being starved of fuel,,,,it runs ok when the mixture screw on the carb is screwed right in but then this affects the bike when the throtle is opened but when i unscrew the mixture screw on the carb it stalls ,,,,any help would be greatfull...thanks ps pulling the choke out on tickover stops this
hi ralph thanks for the info i have messured the sag and it is 100mm at the rear and 40mm at the front,,,i do not know the full travel on the bike so what would be a third in mm,,thanks tom
hi just getting the bike ready for its first trial,,,anybody out there tell me how much sag there should be for a 2007 gas gas front and back ,,,i am 15 stone in wieght,,,,thanks tom
ye,,, your right ,,nothing that can not be fixed,,,,just do not want it rattling loose harf way through a trial..
not had the bike long,,,and with other bikes i have had in the past i have never had the case bolts vibrate loose before,,,going to order a new seal,,,and check the bolts after every ride,,,,,the way its going i think it is going to be a very short relasionship with the gasgas,,,,fingers crossed for my first trial on it this weekend...tom
hi there ,went to the 2007 txt pro 300 raga to night and it had an oil leek because the clutch casing bolts had come loose part of the gaskit was sticking out.i slid the gaskit back in tightend the bolts and re filled with oil and it seems alright, is it normal for them to come loose and would it do any harm if i locktight them in place.
tryed the fan on a 12 volt battery,worked,tryed bypassing thormostat,not working,change thermostat and fan module,,working ,,,,great turned out to be the fan module,,,,what a pig to change the thermostat,,though ..are the spanish trying to take the p*** or what,,,i left the bye pass cable for the thermostat stiil connected to earth so if there was a thermostat failer in the future its just a quick change from the white wire off the thermostat to the loop wire ,job done ,,thanks for all the help,,tom
hi there been out and bike got hot,fan did not come on,got home and tryed the fan connected to a 12 volt battery and works fine,,try to loop the fan for it to stay on all the time but could not do it,the wires from the thermostat went to earth and then to a white wire so i tryed to connect them but could not get the fan to stay on any info on this,,,also if it is a faulty thermostat how do you go about replacing it ,,,the bikes a 2007 txt pro 300 raga,,,thanks tom
just got back back in the house,,,cracking day weather has been great had the last hour on the dry setting great could tell a differance in the frist two yards,,,,same result though,,,,,live at fell green so lifes sweet,,,,
stripped the carb this morning,,,,a lot of crap came out of it,,,,put it back together with all the nipples connected to tubing,,,perfect,,,just come back from the morning session no problems,,,bit of dinner then back out,,brill,,,thanks to every one for info it was a great help....tom
