lumbr Posted August 28, 2006 Share Posted August 28, 2006 hi whats the best oil to put in a 250 mono, as i've been out today for the first time on it and the cluch seems to drag , it might be the clutch that as gone but just want to make sure its not the oil first. also it does not rev out right , it goes all rough afer about half revs i tryed changing the mixer screw with not alot of joy, i also tuck the air filter out and tryed it again with no joy (put it back). is there a stiffer spring you can get to fit the sandard shock. please help Quote Link to comment Share on other sites More sharing options...
steveo Posted August 29, 2006 Share Posted August 29, 2006 If your bike is a SY Scorpa 250 you would be best asking you questions in the Scorpa section. Have found the best oil to stop drag or creep is Bel Ray Gear Saver 75 SAE oil. Best to change frequently especially if you ride a lot.I have changed to Putoline and find it gives excellent results also.Would be very surprised if you found your clutch to be shot. Check your plug or fit a newey. Clean and reoil your filter and also check carburettor rubber boots both sides are seated correctly and clamps tight. Not sure of stiffer springs . Quote Link to comment Share on other sites More sharing options...
lumbr Posted August 29, 2006 Author Share Posted August 29, 2006 sorry its a ty250 mono 1986 not the scorpa. Quote Link to comment Share on other sites More sharing options...
paioli Posted August 29, 2006 Share Posted August 29, 2006 gear box, repsol 10\30. clutch, put in another metal clutch plate or a washer in each of the clutch springs, making sure they dont foul the inner or outer clutch basket, this will compress the springs just enought to make the plates bite better. carb, make sure the float level is 21mm with the float bowl gasket removed,try the bike out if the same then try moving the clip up and down the needle by one slot ,assuming its already on the center grouve , also i have found a b6es plug 0.7mm gap tends to burn the 50.1 petrol mix better because its a hotter plug if still the same do another post and tell us what size pilot and main jets you have in your carb. Quote Link to comment Share on other sites More sharing options...
lumbr Posted August 29, 2006 Author Share Posted August 29, 2006 i cant do this till the weekend but its got a 140 + 40 jets in it, but i will measure the float and try it, thanks for the help Quote Link to comment Share on other sites More sharing options...
paioli Posted August 30, 2006 Share Posted August 30, 2006 pilot jet (40) looks ok though you could try a larger main jet up to 150 , also check the reeds are fully closed by looking through the reed block (when removed) you should not be able to see any day light, some times one or two petals tend to lift up, if so get a new set. the air mixture screw only controls slow running so 1 1/4 turns out should be ok. Quote Link to comment Share on other sites More sharing options...
lumbr Posted August 30, 2006 Author Share Posted August 30, 2006 that could be it, on one side of the reeds there is a gap do you think that is the problem. Quote Link to comment Share on other sites More sharing options...
kuelmuel Posted August 31, 2006 Share Posted August 31, 2006 That means it could be kicking some of the lixture back into the carb, try raising the needle to let more petrol in Quote Link to comment Share on other sites More sharing options...
paioli Posted August 31, 2006 Share Posted August 31, 2006 put some new reeds in, then go on to any carb ajustments, pointless trying to tune carb if reeds are u/s, jk hirst sells ty reeds. Quote Link to comment Share on other sites More sharing options...
