Sherco 2.9 Yr2000
Hi all.......Now here is a GOLDEN opportunity to have a laugh at someone else's expense.
If my attatchment works, you should see a piccy of me and my mate changing the gearbox oil on his recently aquired Sherco 2.9 Yr.2000
NOW...after you've stopped laughing...can someone tell us the EASY way to get the oil out??
ALso..it would be great if someone can tell us the fluid levels...i.e. fork oil, gearbox oil, coolant, correct fuel/2T mix....since we dont have a manual.
CHEERS...(and stop laughing!!)
BWAAAHHHHAHAHAHAHAH....
Awwwww.......actually, it ain't so bad. I've seen worse.
On the left side of the engine, remove what looks like the lowest bolt that holds the cases together. It's the drain bolt. And it's pretty long..not just a little plug, so don't get nervous when you pull out a long bolt.
I've been using cheap ATF and changing it every 3 or 4 rides.
Clutch works great, and I figure that's the kind of environment it's made for in terms of shearing and anti-foam properties.
450cc.
