lpd Posted December 28, 2006 Share Posted December 28, 2006 (edited) Ok, so I rebuilt the rear suspension on my 2000 TXT200. Rear shock had a blown seal and I replaced all of the bearings in the linkage. Where do I start for static sag...1/2 inch and rider sag...2 inches? The knob for adjustment at the bottom is this for rebound? Lastly what would be a good starting/factory setup for it? I checked the static sag using a stand and measured the distance of rear sag and then with the weight of the bike and I have 2 inches of sag. I think this is ok. I'm 160lbs with gear. Thanks Peter Edited December 28, 2006 by lpd Quote Link to comment Share on other sites More sharing options...
