Tlr200 Reflex Cdi
i'am new to the forum and could not find anything on this topic.
I need a new cdi for '86 tlr200 reflex, oem part is no longer avaliable and I wanted to know if anybody knowes of an alternitive.
  • 4 weeks later...
Hi crossman,
I'm not sure if I can help. I thought the TLR200 had ign points?
Does your model have electronic ign?
If so, and your electronic advance/mapping "box" has failed, then I would imagine a similar unit could be found from a Honda road model, GL125/145 or similar or one of the many trail bike versions, XR200. Thought these would have been more popular than the TLR. The actual mapping may be slightly different but you could counter that a little by adjusting the static timing - by adjusting the ignition sensor pick up coil position.
Bye, PeterB.
