sectionone Posted May 21, 2007 Share Posted May 21, 2007 A floating front disc allows for side to side movement, but should there also be any up and down movement? Mine does and sometimes makes a clanking noise as well as not stopping well. Does the metal collar around the mounting bolts need to be replaced? Quote Link to comment Share on other sites More sharing options...
martin 305 Posted May 26, 2007 Share Posted May 26, 2007 A floating front disc allows for side to side movement, but should there also be any up and down movement? Mine does and sometimes makes a clanking noise as well as not stopping well. Does the metal collar around the mounting bolts need to be replaced? Hi there had the same problem on my 307 i replaced the cups as they had some wear. When the brake was locked you felt movement like the head bearings were going , it stoped when i changed the cups 6 i think without looking.Hope this helps Quote Link to comment Share on other sites More sharing options...
