sy250 Posted June 17, 2007 Share Posted June 17, 2007 I have a TLR 200 with all the lights etc on. Does anyone know the method please for removing ignition etc and wiring in a kill switch ? Thanks very much for any advice which would be very gratefully recieved Quote Link to comment Share on other sites More sharing options...
hondanut Posted June 17, 2007 Share Posted June 17, 2007 it should be fairly easy, you can just separate the not wanted bit of the loom at the connectors and you can even keep the original on/off switch, just dont disconect the ignition system. i found it quite straight forward and took about 15 mins. Quote Link to comment Share on other sites More sharing options...
sy250 Posted June 20, 2007 Author Share Posted June 20, 2007 Thank You for the advice Quote Link to comment Share on other sites More sharing options...
