August 8, 200719 yr Hi all This is my first bike so I'm looking for some enlightenment from some of you more experienced mechanics: I'm about to 'try' and change the main bearings on my 250cc 2000 Rev 3. I was hoping that one of you might be kind enough to spend a few minutes to give me a rough outline of the process involved. As I appreciate this might be a little time consuming, if this sounds like too much work, could you instead give me some pointers please? thanks, thanks and more thanks =) The engine is already off the bike with the head/top, flywheel, stator, carb
August 8, 200719 yr Author On a more specific note: I'm in the process of prising the block apart, however, on the flywheel side, the crank doesn't seem to want to leave the housing. I've got the two halfs of the block this far apart: Click for larger image However, as you can see in this image, the crank doesn't seem to have left the housing: Click for larger image My initial thought is to get a hammer and knock the flywheel end of the crank back into the block but thought I'd ask you guys first. Or, perhaps the crank is meant to come off with this side of the block and needs to be undone from the other side? Which would mean removing this bolt and working from there right? Click for larger image Cheers guys. Edited August 8, 200719 yr by Glyph
August 8, 200719 yr Making a note not to let Mr. Davidson work on my bike... Would it be too cheeky to ask if you have a workshop manual?
August 8, 200719 yr Author What! there's a workshop manual? lol Well I'm nearly there. One main bearing is now replaced. I just cant seem to remove the crank now. After referring to the technical diagrams (Thanks swooshdave =)) I can see that I don't need to take the clutch off =) LMAO =) It should just come out now right? No? =S
August 9, 200719 yr The crank will be a tight fit into the bearing so it will take a little force to remove it. I take it your going to replace the seals as well as the bearings ? if so you will need to remove the clutch so you can get the primary gear and weight off to fit the seal. As you have removed the barrel etc already you will have very little resistance to stop the clutch basket turning so you will need a compressor to remove the clutch centre nut. DO NOT attempt to hold the clutch basket, they break very easily and are rather expensive to fix. have fun
August 9, 200719 yr Author Thanks for the advice Baldilocks, I noticed the clutch plate was easy to break Oh well, you live and learn I guess. I'm buggered if I can get the crank seals in now though. I've been trying from inside the crank case though. I'll have to get the clutch basket off and try from the other side.
August 9, 200719 yr Author Just tried the crank seal from the external side of the crank case (flywheel side) and it went straight in =) Do the bearings need lubricating before putting into place? Edited August 11, 200719 yr by Glyph
August 11, 200719 yr Author Does anybody know where I can find the correct torque settings? For crank and clutch basket. Thanks peeps.
August 12, 200719 yr I'm buggered if I can get the crank seals in now though. I've been trying from inside the crank case though. I'm not buying this anymore Glyph, your either an extremely gifted comedian or this is a wind up ! The last bloke to try to fit crank seals from the inside was the DIY guy on Kenny Everett !! the clutch basket nut needs to be tight but theres a lock washer anyway, the primary gear i'd use a windy gun.
August 13, 200719 yr Author I'm not buying this anymore Glyph, your either an extremely gifted comedian or this is a wind up ! LMAO, leave me alone, it's my first bike. Thanks again for your advice though Baldilocks, I've just bought a Wizzer off ebay so I'm waiting for that to arrive before I can remove the clutch basket. Does anybody know a good place to price up a clutch plate?
August 13, 200719 yr i may regret this but whats LMAO stand for ? ring lampkins for clutch plates but they come as a set try either the Trial company or john lampkin imports in Google
August 13, 200719 yr Baldilocks, think its that new fangled text talk writing for Laugh My a*** Off mate
August 13, 200719 yr Baldilocks, think its that new fangled text talk writing for Laugh My a*** Off mate Glyph any chance of a full write up when your done???? I know there will be loads of us wanting to know how to do this if some havent already! Your efforts/mistakes are refreshing that we are not the only ones! Also you may find this interesting....A full engine rebuild http://offwidth.co.uk/bike/crm_rebuild/index.html Although its a crm most of the principles are the same
