September 3, 200719 yr Can anyone offer some help?. I have a gearbox problem ive removed the engine stripped it down but i cant get the casing on the on the gearbox side to split. tripple checked ive left no bolts in place. Ive tapped it knocked try to lever it no joy. How tight are they, is there a technique or just keep percivering. Everything is off the engine thanks in advance
September 3, 200719 yr Hi Gav, if its the section motor you will need a puller. Big bolt onto end of crank, 3 arms eeach with a screw going into the side case under the flywheel. No other way I finx! Lee
September 3, 200719 yr Author Cheers Lee is there a common fault on the section sounds like something slipping under load, its like the chain sliiping on the sprockets but its inside the engine cheers Gary
September 4, 200719 yr It sounds like you may have lost some teeth...i just bought a set of crankcases from steve goode...maybe he has the gearset also? Lee
September 4, 200719 yr Author Lee are the 303 gearbox anywhere near? i have a few spare bottom ends. Gary
