October 2, 200719 yr I have recently gotten a 1999 315r, now with winter coming I want to mount the headlight but just see the lower screw hole at the base of the headlight surround, there is a threaded hole higher but I don't see anything on the headlight to attach to. Is there another bracket that I should have? Please let me know if anyone has an idea, thanks Edited October 2, 200719 yr by autodoc345
October 2, 200719 yr I have recently gotten a 1999 315r, now with winter coming I want to mount the headlight but just see the lower screw hole at the base of the headlight surround, there is a threaded hole higher but I don't see anything on the headlight to attach to. Is there another bracket that I should have? Please let me know if anyone has an idea, thanks one screw on the bottom yoke and a few cable ties at the fork legs should do the trick headlamp height can be ajusted with a screw inside the headlamp housing cheers
