gasgas280 Posted June 6, 2004 Report Share Posted June 6, 2004 TXT280 2000 Is the front disc supposed to float? or are my mountings worn? Probably a daft question TA ANDY Link to comment Share on other sites More sharing options...
charliechitlins Posted June 6, 2004 Report Share Posted June 6, 2004 I don't think that one floats. If it did, and was worn, it would float (shake) more. As far as I can tell, the biggest advantage of a floating disk is that it does away with the very slight drag that sometimes causes squeaking when the brake isn't applied. If you don't have it, you're not missing much. Link to comment Share on other sites More sharing options...
gasgas280 Posted June 6, 2004 Author Report Share Posted June 6, 2004 Holes in disc are 16mm ish mounting bushes are 15mm giving 1/2mm float But are the holes in the disc supposed to be 16mm? Surely if they were worn they would be oval! ANDY Link to comment Share on other sites More sharing options...
superflytx270 Posted June 6, 2004 Report Share Posted June 6, 2004 Yes mate i believe they are meant to be floating discs. I have them on my 98 tx270 and my cousin has them on his 2002 txt280. I cant see Gas Gas doing away with them after '98 then reintroducing them in 2002. Link to comment Share on other sites More sharing options...
gasgas280 Posted June 6, 2004 Author Report Share Posted June 6, 2004 Thanks Thats 1 less thing to worry about Just the fork stiction thing & snapped bleed nipple to sort now ANDY Link to comment Share on other sites More sharing options...
Please sign in to comment
Sign In Now
