O4 300 Pro Torque Specs
Hi, all,
Does anyone know the torque specs for the head bolts on a 04 300 pro? I need them in inch or foot lbs if possible.
Thanks.
This approximation might help:
Foot pounds /Newton Meters
Front Wheel Axle_______________ 30 to 37/ 40 to 50
Chassis to swingarm fastener_____ 44 to 52/ 60 to 70
Upper shock absorber fastener____ 30 to 37/ 40 to 50
Lower shock absorber fastener____ 30 to 37/ 40 to 50
Handlebars___________________ 13 to 18 /18 to 25
Hand levers___________________ 5 to 7 /7 to 10
Radiator fasteners______________ 13 to 18 /7 to 10
Front bridge wing_______________ 5 to 7 /7 to 10
Brake pedal___________________ 20 to 24 /27 to 32
Muffler fasteners_______________ 13 to 18 /18 to 25
Rear wheel axle________________ 30 to 37 /40 to 50
Rear brake caliper fastener_______ 20 to 24 /27 to 32
Front brake caliper fastener_______ 20 to 24 /27 to 32
Exhaust pipe elbow fastener______ 20 to 24 /27 to 32
Engine fasteners________________ 13 to 18 /18 to 25
Rear brake pump fastener________ 5 to 7 /7 to 10
Spark plug_____________________ 8 to 9 /11 to 12
Ignition fasteners_______________ 5 to 7/ 7 to 8
Clutch fasteners________________ 5 to 7 /7 to 8
Cylinder stud bolt fasteners_______ 18 to 20 /25 to 26
Reed fasteners_________________ 5 to 7/ 7 to 8
Clutch ground fastener___________ 2 to 3 /3 to 4
Crankcases fasteners____________ 5 to 6 /7 to 8
Water pump cap fastener_________ 5 to 6 /7 to 8
Clutch cap fasteners_____________ 5 to 6 /7 to 8
Flywheel fastener_______________ 30 to 32 /40 to 42
Water fastener_________________ 7 to 8 /10 to 12
Ignition cap___________________ 5 to 6 /7 to 8
Engine drain plug_______________ 9 to 10 /12 to 14
Kickstart pedal screw____________ 9 to 10 /12 to 14
Shift pedal screw_______________ 5 to 6 /7 to 8
Cylinder head screws____________ 8 to 10 /11 to 14
Cylinder nut___________________ 18 to 20 /25 to 27
The descriptions are from the manual, so the translation
is close.
Cheers.
Jon
Thanks for the reply, I got the compression reducer installed and WHAT a difference! The bike is much more mellow to ride with no major loss of power noticeable. I'm very happy It's the best money I've spent on the bike.
