August 27, 200818 yr Hi guys. I own a 1992 aprilia climber 280R. The rear shock has gone and is bouncing around, making it hard to drive. Anyone know where to get a replacement part? Cheers Nathan
August 28, 200818 yr Falcon can rebuild it for you. However after checking on the rebuild price, initially i modified a 303 (I think) fantic shock (roughly the correct length) to fit then eventually found a secondhand climber shock on ebay..... With regard to the forks, I fitted a set of conventional fantic 303 forks and yokes which made a big difference over the original USD - made a spacer to fit the smaller spindle size and fitted the original front wheel. Andy
August 28, 200818 yr I had a Beta shock rebuilt by Falcon once, did a good job and was still perfoming well when I sold it a couple of years later.
