September 15, 200818 yr Blocky, I cleaned the hubs with wet and dry paper(wet),primed them,used some car wheel spray paint and then car wheel lacquer, I was going to get them powder coated but thought I would probably have problems with the thickness of the coating where the spoke heads sit.
November 23, 200916 yr Message for Andy T Did you make up the airbox from scratch or is it a modified version? Any help would be most welcome as your airbox looks about the most stylish i have seen in a long while. Cheers
