October 4, 200818 yr hi i need torque settings for the cylinder barrel nuts & cylinder head bolts for a jt 250 1993 cheers
October 4, 200818 yr hi i need torque settings for the cylinder barrel nuts & cylinder head bolts for a jt 250 1993 cheers I'm trying to remember the capscrew size of the Jt head, but I think they go to about 12 ft lbs (16 Nm) and the cylinder base nuts to about 18 (25 Nm) ft lbs. I'm pretty sure the head capscrews use an o-ring under the washer, if so, be sure to grease them so they don't bind and tear during installation. After running for a time and cooling off, it's a good idea to re-torque them to prevent future loosening. Jon
May 7, 201115 yr I'm trying to remember the capscrew size of the Jt head, but I think they go to about 12 ft lbs (16 Nm) and the cylinder base nuts to about 18 (25 Nm) ft lbs. I'm pretty sure the head capscrews use an o-ring under the washer, if so, be sure to grease them so they don't bind and tear during installation. After running for a time and cooling off, it's a good idea to re-torque them to prevent future loosening. Jon hi there wud these torque settins be the same for a 95 jt 250
