How Much 2 Stroke Sherco
How much 2 stroke should i mix with my sherco 250 03 model,
at the min am mixing 25:1 in 5L of petrol many thanks.
80:1 is a reasonable ratio. Thats 80 parts petrol to 1 part oil, or 63ml of oil per 5L of petrol. For this use a good quality fully synthetic oil.
Yes tt5th has it pretty much spot on.
I have a 2003 290 and run it at 80:1.
12.5 mls per litre.
I usually make 4 litres up, so thats 50 ml of decent two stroke oil to 4 litres of petrol giving some slosh space in a 5 ltr can.
THANKS GUY'S BEEN VERY HELPFULL
I WILL DO THT NXT TIME I FILL MY CAN UP
CHEERS!
sorry but is 80ml oil in 5l petrol 100:1? If so I reckon that may be aiding my fuel problems?
Do they offer MATH in school, there? Example!
5000 / 62.5 = 80:1
4000 / 50 = 80:1
or
5000 /80 = 62.5 ml
4000 /80 = 50 ml
Now try your own with just one liter! Convert all that to a US gallon jug an tell the answer! :wub: in ml! :P
Ive just never sat around and thought about it. The dealer just told me to use 80ml per 4.9 litre. Used it ever since but never really had a strong tickover!
Will try it tommorow when mixing the fuel up.
  • 1 year later...
blimey, ive never run a 2 stroke at those kind of ratios.. 33:1 is best for 2 strokes and dont use a motocross race oil as its 2 heavy.. you need a good road 2 stroke oil.. like helix 2t or morris plus 2...
you loose power running too rich and there is less lubrication for the engine parts.
Edited by BenC1980
I got told and have mixed 10 litres up with 200ml of oil in. Is this far too much?
no thats fine,
Good, I was paranoid about leaving the dregs in the bottom of the measurung cup but after reading that some people only put 62ml into 5 litres I'm not so worried now!
Can't say I've ever fouled a plug in a trials bike while running 80:1 with a good oil-Motorex powercross which claims to be usable up to 100:1 in mx bikes
you wont at 80:1 becuase theres not much oil in there..
80:1 is plenty
Im surprised yours runs at all using 33:1!!!!!!!
It must be choking up your pipe.
