orange250 Posted January 24, 2009 Share Posted January 24, 2009 hi I am new here and to trials. I am looking for a first bike, I have rode enduros before. I have the chance of TXT 250 pro 2004. Would this be ok as a first bike? Any thing to look out for? Seems quite together. What would be a good price? Thanks for your time. Quote Link to comment Share on other sites More sharing options...
druijs111 Posted January 24, 2009 Share Posted January 24, 2009 Hi, I 've owned a TXT250 pro model 2002. It's a very friendly, light and nimble bike. It's absolutely a great bike for starters. I never had any major problems. What did break was the return spring from the kick-starter. I think Gasgas resolved that problem by 2003, so that should not be a problem. What could be a problem is the clutch. The hydraulic system always tends to leak in the engine case. That causes bad clutch action due to air in the system. I think that this problem was fixed on the 2005 model by changing to mineral oil in de hydraulic system of the clutch. On my 2002 bike I swapped the complete hydraulic clutch system (that included the right side engine case) for 2005 parts. It solved the problem. Also the stock Sachs rear shocker wears out quickly. I tossed it for a WP unit within two years, because there was no compression damping left (I'm not kidding). The WP was miles better then the stock shocker also. I now run an Quote Link to comment Share on other sites More sharing options...
orange250 Posted January 24, 2009 Author Share Posted January 24, 2009 Thanks. Quote Link to comment Share on other sites More sharing options...
