g520 Posted February 18, 2009 Share Posted February 18, 2009 Hi I wanted to change the oil on my new-to-me SY250. To my delight the head of the oil plug had been stripped Quote Link to comment Share on other sites More sharing options...
montman Posted February 18, 2009 Share Posted February 18, 2009 The drain plugs are really soft metal. Mine rounded off the first time I drained when the bike was new. I gently drifted it loose and replaced with a cut down standard type bolt. No probs since. Quote Link to comment Share on other sites More sharing options...
paulmac Posted February 18, 2009 Share Posted February 18, 2009 (edited) Don't worry mate you're not the first to strip the nut - done it myself - the OEM part is a pile of c***p as Montman says. One of the Edited February 18, 2009 by paulmac Quote Link to comment Share on other sites More sharing options...
trialanderror Posted February 18, 2009 Share Posted February 18, 2009 hi, i think the drain plug of a honda c90 will fit, and being honda ( much better quality ), hope this helps cheers Quote Link to comment Share on other sites More sharing options...
g520 Posted February 19, 2009 Author Share Posted February 19, 2009 The oil plug is out. After trying two different Vise-Grips, several Pliers, chisel/hammer and several more things I welded a nut to the oil plug. Pretty brutal approach. The trick to avoid heating the aluminum cases was to weld for only a second at a time and cool in between with water. There was almost no heat transfer to the cases so I don Quote Link to comment Share on other sites More sharing options...
