She Was Born In 1959
Hi,
The story of my BSA/Burman.
Built and ready for race in 1959, sold in 1960. no small- big end rebuild..
http://i633.photobucket.com/albums/uu54/pa...et/66010006.jpg
Found and rebuilt 1987. Few changes but no small- big end rebuild..though, same sprockets ..19" replaced by 18".
http://i633.photobucket.com/albums/uu54/pa...SA071024006.jpg
Rebuild start up 2009
http://i633.photobucket.com/albums/uu54/pa...t/BSA071230.jpg
Sprockets and chain 520->420, weight saving 2558g..B&C
http://i633.photobucket.com/albums/uu54/pa...sprocket16t.jpg
http://i633.photobucket.com/albums/uu54/pa...SA071230117.jpg
http://i633.photobucket.com/albums/uu54/pa...SA071230118.jpg
Cheers
Thanks Vinnie,
There is not much to show really... ;)
Today
Did line up the gear box with spare engine and did lower the sving arm joint inline with the final axle and sat the chain line for welding the flange ears to the drum.., started to moulding for a new ally oil tank.....
Im pretty stucked right now, have waited for a pair of y... since jan.. a bottle neck.. :D No hurry, she can rest this season.
Have not 100% descided chassie geometry, fix/weld upper shock brackets, weld peg brackets, handle bars pos, a new front spindle, front fender bracket joints...............
Cheers
Edited by Pat
  • 4 weeks later...
  • 4 weeks later...
  • 3 weeks later...
You should maybe buff the Husky motif off if you want it to look period !
Looking good.
Edited by B40RT
Thanks B40RT,
Have never read about period defined by "parts from one brand/bike" actually, even concidering pur..... no part been changed since 65 :P .
SSDT P65 regs is my bible so far, even if some thinks regs should be loosen up, I dont :o
FYI, hubs + shields Husky 175cc 1956
cheers,
nice looking bike and very interesting comparison of chin/sprokets weight.
i'd have thought that if you turned up at kinlochleven with it you'd ride the first time but might be 'unlucky' in the draw for future rides. the husky bits although period (easily) dont fall easily into the description of 'british' in the regs..
Thanks totalshell,
Not much of a bike yet :-)
A_al or Villiers carbs I do accept but dont understand, but are we seriously discussing; parts only manufactored within the UK as legal for UK P65 nationals or SSDT P65 set up? Guess not.
Edited by Pat
Very nice, how many hours ?
You could try the macro setting on your camera for these sort of shots.
Ross
Thanks Ross,
Manage terrible results with the cell phone cam, when I chose to spend more money on a P65 trials ;)
I have to buy some lathe operations actually becuase of time running out..
Edited by Pat
  • 3 weeks later...
Hi,
Will ask for your opinion regarding oil for pre-unit pre-war engines.
In my book a tot perfect rebuilt engine should be threated with multigrade fylly synt; less carbo, lubr ~even, but have received strictly advice from two reliable sources to use singlegrade mineral..
Yes, for trials gearboxes because of tooth pressaure and ..for better friction KTM 2-s trans because of the std clutch design or Rekluse for that matter..
But inside a fresh 4-s engine/comb chamber, no.
Some said that seals might dislike "cleaning" additives in multigrade, the two seals for my crank are modern, fibre gaskets are from modern mtr..
But I dont know of..
*oil pump requirements
*tolerances verses a modern engine, singlegrade "fill the space better"...
*Bronze bush requirements
As I understand most of you using synt for P65 and some serie is supported by an oil supplier.
________________________________________________________________________________
Carbs, is Amal Concetric MK1 legal for P65, SSDTP65?
Cheers,
Cheers,
Amal MK1 Concentric is legal. ( MK2 Concentrics are not)
