November 1, 200422 yr hi folks anyone able to tell me if the 05 125 beta uses the rev 3 engine or do they still use the techno engine?
November 2, 200422 yr hi folksanyone able to tell me if the 05 125 beta uses the rev 3 engine or do they still use the techno engine? There was picture posted here a while ago of a Rev3 with a 125 ZERO motor, I thought it was a really professional aftermarket job but it came from the factory like that. I'd go with PA for the 2005 Rev3 though.
November 3, 200422 yr From www.betamotor.com.au BETA has just released the REV-3 125cc trials bike. Based on the REV-3 200/250/270 trials bikes using the same frame but featuring a motor with the same design layout as the 200 REV-3. The motor is basically a scaled down version of the 200cc motor sharing the same bottom end. In appearance the 125 is the same as the larger REV-3 's but the 125 is lighter and with much softer power characteristics. This bike is designed for Junior riders so they can gain confidence before graduating to full size bikes.
