May 6, 200917 yr is it possible to fit a 1997 xl125 engine into a 1995 cr125 with a few mods ????? thanks
May 6, 200917 yr Do you have the electrics, cdi, carb, airbox etc and access to some steel plate, an angle grinder, a welding machine and a pillar drill? If you do, then it should be possible. If you are thinking of trying to simply bolt an XL engine straight in, then no.
May 7, 200917 yr If you have the time and the money anything will fit in anything...... When i was a lad a hot mod was xl 185 s in cr 250 or yz 250 chassis if it drives the wrong side turn the swing arm over or put the wheel in the other way round. Good luck
May 11, 200917 yr i'v put a few honda cg 125 engines in to the old cr125's the only issue is the drive sproket as the pitch is different i.e chain size, you have to use the xl200 front drive sprocket have fun and get welding!
