godzilla Posted May 15, 2009 Share Posted May 15, 2009 I am going to service my rev4, can anyone recomend some oil, also has anyone use the hiflo brand oil filters and are they any good? Cheers. Quote Link to comment Share on other sites More sharing options...
fivemeister Posted May 15, 2009 Share Posted May 15, 2009 Hiflo appear to be standard issue - as supplied by Lampkins when I ordered a couple recently for my EVO 300. Quote Link to comment Share on other sites More sharing options...
godzilla Posted May 15, 2009 Author Share Posted May 15, 2009 Thanks for that, What oil do you use mate? Quote Link to comment Share on other sites More sharing options...
nzralphy Posted May 16, 2009 Share Posted May 16, 2009 Hi. This is what i know... 15-50w is specified from Beta. Lampkin's say 40w is fine. 50w makes the clutch a touch heavier/more drag. The bike doesn't like being started in gear. I run Total Grand Prix 4T Fully Synthetic 10-50w motorcycle oil and get very little discoloration at 15hrs between changes. I change the oil filter every second oil change. 40w gave a lighter clutch/gear box. ONLY use a quality FULLY synthetic motor cycle oil. car oils aren't designed for gear box use. You'll need approx 800ml oil per change. The HiFlo oil filters are good'ns, and is what i got from the Beta importer, most motorcycle shops sell them. Ralphy Quote Link to comment Share on other sites More sharing options...
fivemeister Posted May 16, 2009 Share Posted May 16, 2009 Yep - what he said. I use Silkolene 15-50 synthetic (see the evo 250/300 4T thread) This is a good place for oil - good discounts and service....... http://www.opieoils.co.uk/c-773-motorcycle-oils.aspx Quote Link to comment Share on other sites More sharing options...
mikey_boy Posted May 16, 2009 Share Posted May 16, 2009 Same here really, only difference being I used 40w oil, did seem to make the clutch a bit lighter, even still though, your taking your life into your own hands starting it in gear Quote Link to comment Share on other sites More sharing options...
godzilla Posted May 16, 2009 Author Share Posted May 16, 2009 Awesome!! thanks guys.. LEE Quote Link to comment Share on other sites More sharing options...
supermotodaz Posted August 11, 2010 Share Posted August 11, 2010 I am going to service my rev4, can anyone recomend some oil, also has anyone use the hiflo brand oil filters and are they any good?Cheers. Can you tell me what the hi flow part number is for these Quote Link to comment Share on other sites More sharing options...
