November 13, 200422 yr Credit where it's due - I'm going to tempt fate and say how bloody good my 04 290 has been, as it reaches it's first birthday. One full year of competition done including all the Welsh Nationals, a few Novogars, the Manx 2 Day, and club trials every week and it's been a pretty cheap year: Broken one brake lever Bent the gear lever, which after buying a new one, bent back OK so I have a spare. Wheel bearings replaced as usual. Apart from that it's been consumables (tyres/oil/fuel/filters). Incidentally, chain and sprockets are not on the list, because I haven't reached the end of the adjustment (without taking a link out). I'm convinced this is down to using WD40 only on the chain all year. A year on the same chain and sprockets seems unbelievable to me??? I have no irrational loyalty to Sherco. I love the way GasGas rides, like the bulletproof Beta and Montesa and will have a good look around when buying my next one, but this year certainly goes in favour of the Sherco. A good year! Edited November 13, 200422 yr by Bikespace
November 13, 200422 yr Interesting to hear Bikespace. THats just the kind of stuff we should all be posting. Much more usefull than just saying "my bikes the best" I've kept a pretty detailed log on whats happened to my Beta Rev3 2002 (bought it in '03)...and I've gotta say that its lasted pretty well too....BUT..I'm not doing the regular competitions that you are! Keep up the good info!
November 13, 200422 yr I used the WD 40 for a few years now BS, never say owt though, people look at you as if your daft if you tell em that's what you use for a chain lube, I let them get on wi blathering the chain in grinding paste Also good for getting stickers off and cleaning the bike.
November 13, 200422 yr Not really on the theme of the post but how does wd40 make a chain and sprockets last longer. Are you comparing it to a particular aerosol chain lube. We would only use wd40 if we had nothing else. I can see that it penetrates the joints better but the lubricating qualities are not up to the job. Mark T
November 13, 200422 yr Author I do use a fair bit of it, for instance on the Manx 2 day every time I refuelled I gave it a quick spray. My chain always looks immaculate (even if the bike doesn't) no dust, grit, **** to gradually grind things away. It always looks as clean as a new chain. It obviously won't stick around on the chain as long, but it does seem to have worked.
November 13, 200422 yr Its good to hear some advice like that because I always used to use WD40 until some people had a go at me for using it. I am going to start using it agin, its easier to use and alot cleaner. Thanks, Lloyd
November 14, 200422 yr The chain on my Rev-3 is now 6 months old and I've only had to adjust it once. I only ever put WD40 on it and it honestly looks like new. There's a WD40 fan club
November 15, 200421 yr Credit where it's due - I'm going to tempt fate and say how bloody good my 04 290 has been, as it reaches it's first birthday.One full year of competition done including all the Welsh Nationals, a few Novogars, the Manx 2 Day, and club trials every week and it's been a pretty cheap year: been fighting this for too long and just have to do it '95 TYZ on it's 9th birthday, several SSDT, numerous centre trials, nationals, club trials, even subjected to some 'throttle to the stop' road racing around Scottish twisties and so far; still on original piston and rings original clutch engine never been apart never loses water original shock and s/arm bushes bashplate and all of its bolts line up perfectly still does 80mph and a bit It has, finally this year, been treated to some wheel bearings. Hadn't bloody well budgeted for them this year though... Sorry - just couldn't resist it
November 15, 200421 yr Good Call Cheers Bikespace - taken in the spirit in which it was intended.. How about this then 1975 Ossa 250 on it's 29th birthday. Lakes 2 day and Loch Lomond 2 day in 2001, zillions of classic championship rounds over the last 15 years, loads of centre trials (sometimes entered somewhat over ambitiously considering the lack of clutch and brakes and the nature of modern sections..... ) zillions of club trials etc. etc. In other words it's been battered. Excellent in its youth but dementure and frailty setting in. Recently; Too many engine rebuilds to think about. Probably more strip-downs than the tears I've shed... A voracious appetite for pistons. Now on it's third liner and up to maximum again. Probably single-handedly responsible for wiping out Millers entire stock of pistons and rod kits over last few years. Broken frame 7 broken rear brake plates 3 broken front brake plates Several duff ignitions Hideous appetite for swing arm bushes Clutch with more of an aversion to disengaging than Honda have for releasing their 4T bog wheeler. Brakes that actually make you accelerate when applied, the type of acceleration that is only matched by the resultant passage of #### through the bowels and widening of the eyes Repeatedly breaking or bending gear lever as the engine is wider than all of the rolly pollys standing side by side. A recent propensity to pink and knock for no apparent reason causing more detonation than found in the average working rock quarry - culminating in the mother of all blow-ups at this weekend's Classic Experts which I had been so looking forward to and didn't bloody well finish. It is being pensioned off herewith. Who said Gassers were the least reliable
November 15, 200421 yr You certainly is a funny guy. Thats the best post I've read in ages. WIsh I had a mate with an ossa that I could forward it too
November 19, 200421 yr Woody, My dad had an Ossa, and you are right about applying the brakes to gain speed. Which is why I found myself looking up at the clear blue sky at the bottom of a hill with the Ossa taking a "rest" next to me.
November 20, 200520 yr Author Well....It's another year on, so time to tempt fate again. My 04 Sherco has now done two years - engine not been split yet. All the Novogars, Manx 2 day, Lakes 2 Day, various other club trials etc. Since last year I've bought: Rear wheel - just needed a spare Rear mudguard and stickers - old one looking very tatty. The usual - oils/filters/bearings/plugs etc. Chain Sprockets. Brake pads front and rear. I still think you just can't beat that. And to add to the WD40 comments from last year, I'm still on my second set of chain/sprockets (2 years) so averaging more than a year a set. At my weight, it's not getting a particularly easy time. I think that's enough of an indication that WD40 is the way to go. I'm thinking of using WD40 on my boots - surely a pair of boots should last longer than chain and sprockets Maybe it just suggests I'm pushing the thing more than I'm riding it Edited November 20, 200520 yr by bikespace
November 21, 200520 yr Same report as above on my '01 bike and my '03 bike! Looking to get another! Had one kickstart lever break, but maybe because a fall had weakened it. Cheers,
