mcman56 Posted June 18, 2009 Report Share Posted June 18, 2009 My C15 has a clutch actuator (pivot) that threads into the timing cover. I have been told the Cub is the same. It interfaces with the cable and rod. When rotated into the correct location, the threads are not tight. Does this matter? Will it flex around an destroy the threads? Is there a standard correction? Is seems like the threads should bottom as the correct position is met. Link to comment Share on other sites More sharing options...
woody Posted June 18, 2009 Report Share Posted June 18, 2009 Nothing to worry about I'd say. Mine is the same, if you screw it tight it is way out of line for the cable so it needs to be backed off. It was like that when I got the bike and has probably been like it for years. Hasn't caused any damage to the threads. Link to comment Share on other sites More sharing options...
matchlessman Posted June 26, 2009 Report Share Posted June 26, 2009 Manufactuing tolerances wouldn't allow.... Don't forget the little ball bearing in the cup. Link to comment Share on other sites More sharing options...
charlie prescott Posted June 27, 2009 Report Share Posted June 27, 2009 Hi Guy's If you have some spare cash and own a "Cub" I would buy one of Duncan MacDonalds conversions as this is a brilliant bit of engineering and solves any clutch adjustment problems in one. PS I have tapped a cub thread out to a bigger size. Regard's Charlie. Link to comment Share on other sites More sharing options...
mcman56 Posted June 30, 2009 Author Report Share Posted June 30, 2009 Where do I get details or pictures of this conversion? Link to comment Share on other sites More sharing options...
charlie prescott Posted July 2, 2009 Report Share Posted July 2, 2009 Hi Guy's Try This http://www.armac-design.com/Armac_Design/Welcome.html OK. Regard's Charlie. Link to comment Share on other sites More sharing options...
Please sign in to comment
Sign In Now
