danman10270 Posted June 25, 2009 Share Posted June 25, 2009 Just got me a new project to build.Its a xl185 motor ,bore & stroke are 70x56.4.It has an extrenal oil feed to the cam.Barrel is large finned and shortend slightly to match the stroke.The crank has the same steel bands around the crank as per seeley rs200 ,as does the alternater flywheel.Six speed box.I think the piston is tlr rtl as its kr9 hf1.Will it be any good or will it spin up too quick with the shorter stroke.Frame is Seeley with some sort of alloy seat tank unit.Also disc brake front wheel.Does any one know of any history on the engine or bike. Quote Link to comment Share on other sites More sharing options...
big john Posted June 25, 2009 Share Posted June 25, 2009 Std piston is 63mm for one of them! I have one right here... Big John Quote Link to comment Share on other sites More sharing options...
andy m Posted June 25, 2009 Share Posted June 25, 2009 Std XL 185s didn't have an external oil feed did they?? Quote Link to comment Share on other sites More sharing options...
wobbler Posted June 26, 2009 Share Posted June 26, 2009 Dan, Bleeding Hell ! I used tp have one just like that, I think i remember the guy saying it was an RTL piston. Good luck Wobbler Quote Link to comment Share on other sites More sharing options...
