August 9, 200917 yr Hi There Wonder if anyone can help me here. My boy has a TXT 125 2003 Gas Gas and when i was washing it earlier i had it on a stand with the rear wheel off the ground and noticed if i lifted the rear wheel it lifted a bit before coming up tight. If it is on the ground you can notice the wheel dropping slightly if you raise the wheel off the ground. There is no Side to Side movement i can see some slack in the linkage which attaches to the rear shock. Wonder if any one has any comments on this. It may be normal i do not know, If it is not can anyone point me in the direction of the problem. ie. Swing arm bearings, linkage etc. Many Thanks Geoff
August 9, 200917 yr Hay, Sounds like the bearings in the linkage, as i just had to replace them, and good thing to as when it came to bits, all the needle bearings dropped to bits, but by the sounds of things i left mine a bit longer as there was quite alot of play.
August 18, 200917 yr Author HI Jeeves88 Thanks for the reply. I took the linkage apart and sure enough all the needle bearings fell out. So i have replaced them and all seems good now. Thanks Geoff
August 29, 200917 yr Hi ThereWonder if anyone can help me here. My boy has a TXT 125 2003 Gas Gas and when i was washing it earlier i had it on a stand with the rear wheel off the ground and noticed if i lifted the rear wheel it lifted a bit before coming up tight. If it is on the ground you can notice the wheel dropping slightly if you raise the wheel off the ground. There is no Side to Side movement i can see some slack in the linkage which attaches to the rear shock. Wonder if any one has any comments on this. It may be normal i do not know, If it is not can anyone point me in the direction of the problem. ie. Swing arm bearings, linkage etc. Many Thanks Geoff My understanding is that this is completely normal. It's also normal for the needle bearings to fall out when you regrease--they do go back in. Lateral play is the real nemisis-- main swingarm bearings.
