September 8, 200917 yr Hiya,, My clutch is leaking from the master cylinder so ive ordered a rebuild kit but want to ask will i need to bleed the clutch if i do this and how easy is it to bleed the clutch? Thanks
September 8, 200917 yr Hi You kind of have too bleed it, but You will only have too bleed it the easyest thinkable way. Just assemble it and top up the reservoir and the air will probably come up by it self when you move the lever slightly in and out. -Jan
