September 15, 200917 yr Hello, i'm french and my english language is not good...... this is my "work" for my bike. Franck. before and after my job.... it's beautiful isn't it ?
September 18, 200916 yr Author Yes, just for the fun, and "same" to the factory model, the generator cover to ! the tensioner is make in tiane (TA6v) all the bolt ! Franck.
September 18, 200916 yr Ok I like Titanium. A lot. How many bolts are in Titanium and what is the cost? Ralphy
September 18, 200916 yr Author Hello, in this pictures you see all the bolts : Ciao Franck. just with the bolts, the bike is more lighter about ~~2 kilos (and my "bank" ~~ 2500
September 18, 200916 yr Author Sorry, i've make a mistake, the "gain" is about 1.5 kgs maxi, not 2 !!!! Franck.
September 19, 200916 yr Look at that! Sweet! We call it Titanium! Otherwise known as unobtanium $ ! Edited September 19, 200916 yr by copemech
September 19, 200916 yr Hi Franck,, like looking at your photos of your 4rt build, but you need to talk us though what your up to so we have some idear what you are trying to achive... Where are you buying your titanium nuts and bolts from ????? Cheers mikee
September 19, 200916 yr Looks like some superb machining. Are you going bigger CC as well as bigger valves. What is final bike like compared to standard. More power, more torque, more revs. Well impressed with the engineering James
September 19, 200916 yr Author Ok ok, at first : i draw and make (with a friend) all the bolt ! not buy in a dealer. my engine power up kit have 270cc (bore is 80.00) piston "J.E" for CRF + cam shaft HRC + body throtle "two" mape + Termignoni exhaust titane. The resultat is : bof !!!! the "RPM" elevation is "slow", the torque is better, the power is better to, but news vibrations (not big, but........) because the piston is more heavy, it is not for a 4RT..... well, this is my sensation. Franck. Ps:I have a lot of pictures of my bike.......if you want, see the "forumty" in "vos autres machines" and "4RT panerai" good travel........ Forumty = http://www.forumty.com/forumty/phpBB2/view...sc&start=15
